UF_MODL_intersect_objects API missing in NX8 (NXOpen) ?
Hello Freinds,
I was trying to use the API UF_MODL_intersect_objects (which determines the intersection between the two input objects and
outputs information describing the intersection) but i do not seem to find this API in the NXOpen help file for NX8. Have the siemens team come with a new API which has replaced this old one.I have use this API till NX7.5
Any help in this regard will be deeply appreciated.
Amitabh
RE: UF_MODL_intersect_objects API missing in NX8 (NXOpen) ?
It shows up in the API reference, but the .net wrapper seems to be missing. I would guess this is not intentional, you should contact GTAC and bring this to their attention.
www.nxjournaling.com
Thanks Cowski.I will bring it to the notice of GTAC.
Can you please help me out how I can open a complaint regarding the same on the GTAC website.
Amitabh
You'll need a webkey account with GTAC, you can create one here:
https://plmapps.industrysoftware.automation.siemen...
Once you have your webkey account setup, you can go to: Help -> Online technical support -> log an incident with technical support; and fill out a form describing your problem. Or, you can call GTAC support (there is a phone number on the website) if you prefer.
