AWS Edge weld symbol
Can I add an AWS edge weld symbol to the default ANSI weld symbols in SW? If so can you please provide an explanation of how that is done.
I'm running SW2013 sp 5.0
Thank you, Diego
Thank you, Diego
RE: AWS Edge weld symbol
**** WARNING ****
Symbols will NOT be recognised on another system unless the symbols are embedded in the recipients gtol.sym file.
Sylvia
Thanks, Diego
Second, if you do not need to use this symbol within your annotation, you can create it as a block. Blocks can have arrows/leaders, same as annotations.
Matt Lorono, CSWP
Product Definition Specialist, DS SolidWorks Corp
Personal sites:
Lorono's SolidWorks Resources & SolidWorks Legion
The FAQ has been suitably updated.
