proe wf5 - relations in repeat region in bom table
Hi there,
I have a bom table in an assembly drawing with 48 items. I suppose to replace item 31 with a new part number, but I like to keep other item numbers the same. After I replaced item 31, it bumped up to item 48 and every other from item 32 shifted 1 down.
Is there any way that I can keep these items from shifting, because that cause me to change the BOM documentation.
Thanks much,
eti
Thanks much,
eti
RE: proe wf5 - relations in repeat region in bom table
keep_item_numbers yes/no but I'm not
100% certain.
Take a look at this closed thread
http://www.eng-tips.com/viewthread.cfm?qid=6733
which answers your question in a how to format.
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
I think you need to lock the BOM table, ten delete the old entry and the new one will go in at the top.
Ben Loosli
