Parasolid output resolution
So here's my issue:
I am working in 2 CAD systems: NX 8.5.3 and a little known system called CoCreate. We are in the process of launching NX and we still have users working in CoCreate and we are trading data back and forth pretty regularly. My problem arises when I try to export a parasolid from NX and open it in CoCreate. The standard resolution in coCreate is 1.0E-6mm. However, the highest resolution I can get on an imported parasolid is 8.8E-4mm. I have tried working through the issue on the CoCreate side but it seems that the highest output resolution I can get on my parasolid parts coming out of NX is 8.8E-4mm.
So my question is, is there a way to change the output resolution on a parasolid coming out of NX?
John
John
RE: Parasolid output resolution
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
On the CoCreate side when I import the part the maximum resolution that can be used is automatically applied to the part, but I am pretty sure that resolution is being determined during the export process from NX.
Example: If I export a 600mm cube from NX it will import into CoCreate at 1.0E-6mm. However, If I export a smaller designed part (most of what I work in) it will only allow a maximum resolution of 8.8E-4mm or sometimes it is even as low as 1.0E-2mm. These rosolutions are too open for what I need to do with the parts in CoCreate.
So I am wondering if there is a setting somewhere that will allow me to manually control the output resolution of parasolid parts from NX. Since currently it seems to imply that resolution.
Have you tried the PTC ATB, it's somekind of translation tool between NX and Pro/E ( I assume that CoCreate is = Pro/E but new name) I have heard positive reviews of the ATB.
Tomas
That being said, when I get back to the office on Monday I'll check with our R&D people who work with the Parasolid toolkit to see if they know what might be going on here.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
