Movie tool - Can I add comments?
Hello all,
In the modeling application, I am creating .avi files using the Tool command for tutorial purposes. Is there a way to add text comments to the movie? I am using version NX7.5. The ability to add comments can be in NX or in another software outside of NX.
Thanks!
S. Murphy
Sr. Technical Illustrator
Dallas, Texas
Thanks!
S. Murphy
Dallas, Texas
RE: Movie tool - Can I add comments?
You can add comments, zoom frames, allsorts.
And if you record slowly, then you can easily chop moments of "indecision" out of the recordings
Regards, Carl
www.jcb.com
NX 7.5 with TC 8.3
Thanks so much! I will look into Camtasia, sounds perfect. While searching through this forum, I just noticed that someone posted that they open a notepad window while recording in NX.
I really appreciate your help.
www.jcb.com
NX 7.5 with TC 8.3
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6, NX7.5 & NX8.5
Vericut7.2.3
I am definitely going to look into using Camtasia. And, thanks for the tip about Windows Movie Maker.
-Sam
