parameters v. properties
i need help with parameters and properties.
i need to access the diameter of a wire bundle. i can see it on the bundle definition form, no problem there.
now how do i pull it into my VB code? what is the syntax to ask for it?
i know it's part of a sketch but is it a parameter or a property??
i have:
oSelc.Search ("name = circle.1, all")
x2 = oSelc.Item(i).Value.Parent.Parent.Name ---- tells me i am in a sketch.
so how do i ask x2 what it's diameter is??????
right now x2 is just a string, but that's ok.
what do i augment 'oSelc.Item(i).Value.Parent.Parent.Name' with to ask for it's diameter????
i need to use it to crunch some other values that i have imported into my code. the crunching is a no brainer.
my issue is that i can't get it into my code into a variable!
banghead
i'm going nuts!!! cat2cat2
RE: parameters v. properties
This will get the radius value of a circle (in sketch or an edge in 3D). It will give you some ideas...but I know for bundles is a different story, so, a sample file would be good to have it to test on it.
CODE --> CATScript
Dim Language As String
Language="VBSCRIPT"
Sub CATMain()
Dim  colDocum        As Documents
Dim  DocActivo       As Document
Dim  part1           AS Part
Dim  sStatus             As String
Dim  mySelection         As Selection
Dim InputObjectType(0)
InputObjectType(0) = "AnyObject"
Dim refBorde              As Reference
Set DocActivo = CATIA.ActiveDocument
Set part1 = DocActivo.Part
Set mySelection = DocActivo.Selection
MsgBox "Select a circle "
Status = mySelection.SelectElement2(InputObjectType, "Select a circle or hit ESCAPE: ", True)
   If (sStatus = "Cancel") Then
	Exit Sub
   End If
Set refBorde = mySelection.Item(1).Value
Dim TheSPAWorkbench As Workbench
Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench")
Dim TheMeasurable As Measurable
Set TheMeasurable = TheSPAWorkbench.GetMeasurable(refBorde)
myRadius = TheMeasurable.Radius
MsgBox TheMeasurable.Name & " (meaning Radius) = " & myRadius
mySelection.Clear
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
CODE -->
Sub Get_Diameter()
Dim partDocument1 As Document
Set partDocument1 = CATIA.ActiveDocument
Dim oPart As Part
Set oPart = partDocument1.Part
Dim oBody As Body
Set oBody = oPart.Bodies.Item("PartBody")
Dim selection1 As Selection
Set selection1 = partDocument1.Selection
selection1.Clear
selection1.Search ("name = circle.1, all")
x2 = selection1.Item(1).Value.Parent.Parent.Name
Dim oSketch As Sketch
Set oSketch = oBody.Sketches.Item(x2)
Dim geometricElements1 As GeometricElements
Set geometricElements1 = oSketch.GeometricElements
Set joe = geometricElements1.GetItem("Circle.1")
Diameter = (joe.Radius / 25.4) * 2
End Sub
i hope i did not confuse you ... i'm NOT trying to change the diameter. i just want to read it.
i tried this per your code ... i added some msgboxes to help
Dim oPart As Part
Dim oBody As Body
selection1.Clear
sCount = selection1.Count
For i = 1 To sCount
x2 = selection1.Item(i).Value.Parent.Parent.Name
joeR = joe.Radius
joeD = (joe.Radius) * 2
msg = "selection1 x2 = " & x2
msg = msg & vbNewLine & "radius = " & joeR
msg = msg & vbNewLine & "diameter = " & joeD
Buttons = vbOKCancel + vbDefaultButton1
Title = "diameter found ..."
x = MsgBox(msg, Buttons, Title)
If x = vbCancel Then
oSel.Clear
Exit Sub
End If
Next
it failed. see attachment ...
i do not have the license for Electrical Workbench..
I think that the code may work because the circle its on the sketch.
But i did not know that is different.. sorry
fredo, how do i access bundle parameters?
Just for curiosity.... the name of the body where you have placed the sketches is "Partbody".. right??
