NEMA L6-20R receptacle power supply.
The wiring voltage for NEMA L6-20R receptacle is 250V based on the NEMA chart. Is 250V the maximum voltage that can be applied to the L6-20R receptacle? In other words, can I provide power to this receptacle from both 208/120v panel and 240/120v panel?
Thank you for helping with this question in advance.
RE: NEMA L6-20R receptacle power supply.
