How to calculate the vapor fraction at te outlet of a pipeline at the start up conditions?
HI,
I am workin on propane loading terminal. The propane from the storage tank is flowing through pipe line of 5200 feet before it feeds the ship. at the start up conditions, the pipe will be at the atmospheric temperature ( 105 F). The propane from the storage tank (down stream of the pump) is at -141 F and 65 Psig, this will eneter a pipe which is at 105 F. Since the pipe is at the higher temperature, the propane exit temp will be higher and may also form some amount of vapor.But this vapor rate will change from minute to minute as the pipe gets cooldown. I want to know how long does it take to cooldown the peipe completly to what ever the fluid outlet temp is? and also how much vapor will be generated during this period? we are planing to send the vapor back to the storage tank, and the vapors from the storage tank will be compressed and send back to the storage tank itself. It is just a closed loop vapor recompression. I want to kknow the vapor generation rate to check whether my existing compressor can handle that rate. if not the pressure in the tank will build up. generally these tanks operates at atmpsphric pressure and can handle upto 1 Psig. This pipe lline is having 6" of polyisosyrene insulation, the wind velocity is 105 miles/hr, ambient air temp is 105 F, 24" stainless steel pipe ( O.D: 24", I.D: 23.25"), flowrate is 500000 lbs/hr. I guess for my calculation here i can ignore the insulation and the ambient temperature, because when the fluid enters 105 F pipe there won't be any heat transfer between the ambient and the propane as it has the insulation. A method for hand calcualtion is apprciated, also let me know if there is a way to do this is Hysys? let me know if you need any other info.
Chemico 822.
Chemico 822.
RE: How to calculate the vapor fraction at te outlet of a pipeline at the start up conditions?
Given the realtive size of the pipeline, wall thickness and the insulation, I would have thought that the steel would cool down within a minute or less. For vapour, at least one option is to calcualte the heat energy in the steel at 105F and -132F and assume that all that energy is transferred into the latent heat of evaporation of the liquid. This should give you a total vapour amount.
By the way did you really mean 105 miles an hour wind speed?? I can't imagine much loading or unloading going ahead at that wind speed...
Chemico822.
