save expressions from UI Styler
Hi everybody,
I´ve programmed a nx journal (in VB.Net for NX 8.5) that asks the user to specify parameters. After this, the journal saves them in tools->expressions.
Here is an example of a program that asks for a diameter and saves it in tools->expressions (Can´t post original):
Option Strict Off
Imports System
Imports NXOpen
Imports System.Windows.Forms
Module Module1
Dim theSession As Session = Session.GetSession()
Public workPart As Part = theSession.Parts.Work
Sub Main()
Dim myDialog As New Dialog1
myDialog.ShowDialog()
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image when the NX session terminates
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
End Function
End Module
Public Class Dialog1
Private Sub OK_Button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles OK_Button.Click
Me.DialogResult = System.Windows.Forms.DialogResult.OK
Dim diameter_expr As String = "diameter"
Dim diameter_value As String
diameter_value = TextBox1.text
Dim unit1 As Unit = CType(workPart.UnitCollection.FindObject("MilliMeter"), Unit)
Dim expression1 As Expression
expression1 = workPart.Expressions.CreateWithUnits(diameter_expr & "=" & diameter_value, unit1)
Me.Close()
End Sub
Private Sub Cancel_Button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Cancel_Button.Click
Me.DialogResult = System.Windows.Forms.DialogResult.Cancel
Me.Close()
End Sub
End Class
This one works pretty good.
But now i think it would be more comfortable programming this in UI Styler.
I´ve never worked with the UI Styler but that´s what i´ve designed:
It opens correctly in NX but i don´t know how to save the input from linear_dim0 in tools->expressions.
Where do i have to write the code?
' WARNING!! This file is overwritten by the Block UI Styler while generating
' the automation code. Any modifications to this file will be lost after
' generating the code again.
' Filename: [...]
' This file was generated by the NX Block UI Styler
' Created by: ...
' Version: NX 8.5
' Date: ...
' Time: ...
' Purpose: This TEMPLATE file contains VB.NET source to guide you in the
' construction of your Block application dialog. The generation of your
' dialog file (.dlx extension) is the first step towards dialog construction
' within NX. You must now create a NX Open application that
' utilizes this file (.dlx).
' The information in this file provides you with the following:
' 1. Help on how to load and display your Block UI Styler dialog in NX
' using APIs provided in NXOpen.BlockStyler namespace
' 2. The empty callback methods (stubs) associated with your dialog items
' have also been placed in this file. These empty methods have been
' created simply to start you along with your coding requirements.
' The method name, argument list and possible return values have already
' been provided for you.
'These imports are needed for the following template code
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.BlockStyler
'Represents Block Styler application class
Public Class diameter
'class members
Private Shared theSession As Session
Private Shared theUI As UI
Private theDlxFileName As String
Private theDialog As NXOpen.BlockStyler.BlockDialog
Private group0 As NXOpen.BlockStyler.Group' Block type: Group
Private linear_dim0 As NXOpen.BlockStyler.LinearDimension' Block type: Linear Dim
'Bit Option for Property: SnapPointTypesOnByDefault
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_UserDefined As Integer = 1
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_Inferred As Integer = 2
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_ScreenPosition As Integer = 4
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_EndPoint As Integer = 8
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_MidPoint As Integer = 16
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_ControlPoint As Integer = 32
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_Intersection As Integer = 64
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_ArcCenter As Integer = 128
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_QuadrantPoint As Integer = 256
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_ExistingPoint As Integer = 512
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_PointonCurve As Integer = 1024
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_PointonSurface As Integer = 2048
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_PointConstructor As Integer = 4096
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_TwocurveIntersection As Integer = 8192
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_TangentPoint As Integer = 16384
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_Poles As Integer = 32768
Public Shared ReadOnly Dim SnapPointTypesOnByDefault_BoundedGridPoint As Integer = 65536
#Region "Block Styler Dialog Designer generator code"
'Constructor for NX Styler class
Public Sub New()
Try
theSession = Session.GetSession()
theUI = UI.GetUI()
theDlxFileName = "...\diameter.dlx"
theDialog = theUI.CreateDialog(theDlxFileName)
theDialog.AddApplyHandler(AddressOf apply_cb)
theDialog.AddOkHandler(AddressOf ok_cb)
theDialog.AddUpdateHandler(AddressOf update_cb)
theDialog.AddInitializeHandler(AddressOf initialize_cb)
theDialog.AddDialogShownHandler(AddressOf dialogShown_cb)
Catch ex As Exception
'---- Enter your exception handling code here -----
Throw ex
End Try
End Sub
#End Region
'------------------------------- DIALOG LAUNCHING ---------------------------------
' Before invoking this application one needs to open any part/empty part in NX
' because of the behavior of the blocks.
' Make sure the dlx file is in one of the following locations:
' 1.) From where NX session is launched
' 2.) $UGII_USER_DIR/application
' 3.) For released applications, using UGII_CUSTOM_DIRECTORY_FILE is highly
' recommended. This variable is set to a full directory path to a file
' containing a list of root directories for all custom applications.
' e.g., UGII_CUSTOM_DIRECTORY_FILE=$UGII_ROOT_DIR\menus\custom_dirs.dat
' You can create the dialog using one of the following way:
' 1. Journal Replay
' 1) Replay this file through Tool->Journal->Play Menu.
' 2. USER EXIT
' 1) Create the Shared Library -- Refer "Block UI Styler programmer's guide"
' 2) Invoke the Shared Library through File->Execute->NX Open menu.
Public Shared Sub Main()
Dim thediameter As diameter = Nothing
Try
thediameter = New diameter()
' The following method shows the dialog immediately
thediameter.Show()
theUI.NXMessageBox.Show("Block Styler", NXMessageBox.DialogType.Error, ex.ToString)
Finally
If thediameter IsNot Nothing Then
thediameter.Dispose()
thediameter = Nothing
End If
End Try
End Sub
' This method specifies how a shared image is unloaded from memory
' within NX. This method gives you the capability to unload an
' internal NX Open application or user exit from NX. Specify any
' one of the three constants as a return value to determine the type
' of unload to perform:
' Immediately : unload the library as soon as the automation program has completed
' Explicitly : unload the library from the "Unload Shared Image" dialog
' AtTermination : unload the library when the NX session terminates
' NOTE: A program which associates NX Open applications with the menubar
' MUST NOT use this option since it will UNLOAD your NX Open application image
' from the menubar.
Public Shared Function GetUnloadOption(ByVal arg As String) As Integer
'Return CType(Session.LibraryUnloadOption.Explicitly, Integer)
Return CType(Session.LibraryUnloadOption.Immediately, Integer)
' Return CType(Session.LibraryUnloadOption.AtTermination, Integer)
End Function
' Following method cleanup any housekeeping chores that may be needed.
' This method is automatically called by NX.
Public Shared Sub UnloadLibrary(ByVal arg As String)
Try
End Try
End Sub
'This method shows the dialog on the screen
Public Sub Show()
Try
theDialog.Show
End Try
End Sub
'Method Name: Dispose
Public Sub Dispose()
If theDialog IsNot Nothing Then
theDialog.Dispose()
theDialog = Nothing
End If
End Sub
'---------------------Block UI Styler Callback Functions--------------------------
'Callback Name: initialize_cb
Public Sub initialize_cb()
Try
group0 = CType(theDialog.TopBlock.FindBlock("group0"), NXOpen.BlockStyler.Group)
linear_dim0 = CType(theDialog.TopBlock.FindBlock("linear_dim0"), NXOpen.BlockStyler.LinearDimension)
End Try
End Sub
'Callback Name: dialogShown_cb
'This callback is executed just before the dialog launch. Thus any value set
'here will take precedence and dialog will be launched showing that value.
Public Sub dialogShown_cb()
Try
'---- Enter your callback code here -----
End Try
End Sub
'Callback Name: apply_cb
Public Function apply_cb() As Integer
Dim errorCode as Integer = 0
Try
errorCode = 1
End Try
apply_cb = errorCode
End Function
'Callback Name: update_cb
Public Function update_cb(ByVal block As NXOpen.BlockStyler.UIBlock) As Integer
Try
If block Is linear_dim0 Then
'---- Enter your code here -----
End If
End Try
update_cb = 0
End Function
'Callback Name: ok_cb
Public Function ok_cb() As Integer
Try
errorCode = apply_cb()
errorCode = 1
End Try
ok_cb = errorCode
End Function
'Function Name: GetBlockProperties
'Returns the propertylist of the specified BlockID
Public Function GetBlockProperties(ByVal blockID As String) As PropertyList
GetBlockProperties = Nothing
Try
GetBlockProperties = theDialog.GetBlockProperties(blockID)
End Try
End Function
End Class
But where to place the code to save the parameter?
Is it the same code as in the Journaling?
thanks
Kai
Option Strict Off
Imports System
Imports NXOpen
Module Module1
Sub Main()
End Sub
End Function
End Module
Me.Close()
End Sub
Me.Close()
End Sub
End Class
' Filename: [...]
' Created by: ...
' Version: NX 8.5
' Date: ...
' Time: ...
Option Strict Off
Imports System
Imports NXOpen
'class members
Public Sub New()
Try
theUI = UI.GetUI()
Throw ex
End Try
End Sub
#End Region
' 1. Journal Replay
' 2. USER EXIT
Try
thediameter.Show()
Finally
End If
End Try
End Sub
' from the menubar.
End Function
Try
End Try
End Sub
Public Sub Show()
Try
theDialog.Show
End Try
End Sub
theDialog.Dispose()
theDialog = Nothing
End If
End Sub
Try
End Try
End Sub
Try
End Try
End Sub
Try
errorCode = 1
End Try
End Function
Try
End If
End Try
update_cb = 0
End Function
Try
errorCode = 1
End Try
ok_cb = errorCode
End Function
Try
End Try
End Function
End Class
thanks
Kai
