how to delete intersecting perpendicular lines
hoe to delete intersecting lines in given fig...
RE: how to delete intersecting perpendicular lines
Can you provide an example (at least a picture) of what you mean?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Never seen a dim do that before.
Maybe edit the style of the TED and put it on automatic placement?
www.jcb.com
NX 7.5 with TC 8.3
Yea, either use the 'Automatic Placement' option or just do a better job of indicating the origin when using 'Manual Placement'.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Even if you delete the crossing dimension line, the dimension text needs to be relocated. I would simply relocate the dimension.
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
