Export Tables from NX7.5
This is my first post, I work in a teir one automotive supplier.
We have part tables on our 2D drawings we can edit individual cells but we cannot seem to be able to export the whole table.
We have found the export table option but it won't let us select the tables.
I believe the program identifies the text as a datanote even though visually it is represented as a table.
The drafter thinks the 2D drawing was created in idea's before being converted to NX we do not have access to the idea's file if it was created this way.
Is there a way round this?
p.s. I am unfamilure with NX and do not have the software on my PC I am asking on behalf of the drafter. Although it will be me manually retyping it into excel if there is no work around!
RE: Export Tables from NX7.5
This is a way I do it:
Select the Part List in your Part Navigator
Right Mouse Button - Select Export
Output Location - File
File Name - You specify where ( add .txt)!!!!!
Format - Tabs between Columns
You open a spreadsheet and add Data from Text
Hope this helps.
thanks for the help but no this didn't work.
The parts are not in the parts list.
The 2D drawing has 2 tables on it these tables contain text that can be edited individually but the program does not see it as a table it classes the text as a data note
you can copy each text string individually but this would be no quicker to just manually retyping it. Plus I don't have cad so I would have to rely on the drafter/designer doing it and they are much too busy to do that.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
The code isn't perfect (I only had 1 file to test on), but it should give you a good start.
www.nxjournaling.com
