ASTM 2729 for sanitary drains
IPC Table 1102.5 mentioned the use of PVC pipes as per ASTM 2729 for subsoil drains.
Can we use the same for sanitary drains like for water closet?
RE: ASTM 2729 for sanitary drains
PVC pipe per ASTM D2729 - 11 is probably acceptable for building drains. However, you will have to use the materials specified in the plumbing code that was adopted by the municipality where you are located.
