Wet Gas Dryer
Wet Gas Dryer
Hi, I am looking into a project where an existing pipeline/gas field will tie-in to a gas delivery station. However the gas is wet and I need to select a dryer. I haven't done much with driers before.
Flow rate on this pipeline is not much (normal operation is only 100,000 standard cubic feet/2830 Sm3 per day).
Also the pressure is not much either (normally 180 psi/1400 kPag.
I did some research on the net but most of the available units are for large flow rates.
Does anyone know of any proprietary gas driers that I can look into? Or any guidance?
RE: Wet Gas Dryer
RE: Wet Gas Dryer
From what i can figure, the small unit does 120,000 at 200 psig. You usually need a pair to blow the other one dry on a regular basis.
Others are available. You also need a vent or a flare as the unit dries itself by running dry gas thought it which is then flared.
RE: Wet Gas Dryer
I do an exercise in my class where you are using one for 250 MSCF/d at 50 psig and 100°F. In this example the dryer is able to get the water content from 743 lbm/MMSCF down to 398 lbm/MMSCF, but you have to us 30 lbm/day of salt. Where I've seen this tried for applications like the OP, the field guys get really sick of schleping bags of salt pretty quickly.
David Simpson, PE
MuleShoe Engineering
Law is the common force organized to act as an obstacle of injustice Frédéric Bastiat
