I need help reading ecu pin on Bosch Motronic ME7.1.1.
thread67-137036: BOSCH MOTRONIC ME7.1.1
Can someone please help me with software that will read the pin code of a Bosch Motronic ME7.1.1. ? I am able to read pin codes in Vw's up to 04 with my software via obd2. I am trying to pull a code on a 06 2.5 beetle and all I can do is reed the eeprom.
RE: I need help reading ecu pin on Bosch Motronic ME7.1.1.
I'm not 100% sure what you are asking but VAGCOM is most likely what you need.
ms
