Necessary to remove pavement striping before paving?
The roads on our project will be constructed at the beginning of a multi-year phased construction project. The owner has opted to place the final pavement lift at the end of the project (probably 3 years after the first pavement lift is placed). We are going to stripe the roads with the initial pavement lift. Striping will be glass-bead, non-thermoplastic paint.
Is it necessary to remove this striping prior to placing the final overlay? My hunch is that it's okay not to - cleaning the road of debris and a good tack coat will provide sufficient bond between the initial pavement lift and final overlay lift. Am I missing something?
Thanks!
Thanks!
RE: Necessary to remove pavement striping before paving?
Mike Lambert
