Chemical Grouting CMP Pipe
We have a situation where we are looking to chemical grout a CMP pipeline that runs partially under a building in order to seal off infiltration leaks at the joints. However, is it possible to chemical grout a CMP pipe with standard packer equipment? Thank you.
RE: Chemical Grouting CMP Pipe
Some simple things that can seal CMP: 100% silicone sealant, green slime (lots of it) closed-cell polyurethane foam, rubber gaskets with a hose-clamp type fitting, etc.
Just some ideas.
Althalus
