Routing and deform feature
Im involved in a project where we want to use routing to define and create the cabling for elecrtical connector. Then the idea is to use deform feature to alter the cable path when applied to a different area of the assmebly. I thought i had seen this technique being used in the past but not familiar enough with routing to know how to set it up. Anyone have any experience with a similar scenario?
Thanks in advance.
jonnyra
Thanks in advance.
jonnyra
RE: Routing and deform feature
Add connectors a to assembly b,
route paths between connectors,
define sweep features as deformable
add to parent assembly c
deform assembly b
override position of connectors a within the context of assembly c
move in context of assembly c
you can go one step further and create a part family of connectors sharing common routing ports, allowing connectors to be interchanged without losing associativity.
Hopefully this is clear.
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
I'm trying to do exactly what you described. Unfortunately without much success because it fails at the fourth step of your description. Maybe you could have a look at http://www.screencast.com/t/fybyNq7z3W and comment what I'm doing wrong. I would really appreciate it.
Thanks a lot!
