Parts disappear in assembly drawing
I have a large assembly. In this i create a section view of the assembly. I want one of the subassemblys in this view to be non sectioned but when i make it non sectioned some of the parts in the subassembly disappear. I have tried the 'interference' options on the 'Hidden Lines' tab of the View Style dialog with no success. Nothing seems to be hidden, nothing hidden in the view dependant edits.
I have tried to rearrange parts in the assembly to provoke changes in the view but this seams to just make other parts hidden.
This is a assembly with a couple of pretty large subassemblys.
What more can i do or check to try to solve this problem?
Im using NX 6
Im using NX 6
RE: Parts disappear in assembly drawing
anyone?
All layers are visible
I not sure about the "small features" thing, i have to check that as soon as possible.
Thank you SDETERS
Ryan Lee
Mechanical Project Engineer
NX 6.0.5.3
NX 9.0.0.19(testing)
If you can think it it can be modeled
Maintenance pack (if any) is shown in green square.(attached image)
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.2 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
Thanks nutace, NX Patch is Unknown? NX Version is 6.0.5.3.
Forgot to tell you we also have Teamcenter if that matters?
www.nxjournaling.com
