Routing Mechanical standard parts (inch, metric)
Hallo!
I use Routing Mechanical application.
I will need use parts “mm” and “inch” in one project. When I add environment variable “UGII_ROUTING_KIT_UNITS=metric” in my Windows I have mm whilst “UGII_ROUTING_KIT_UNITS=inch” I have inch. It is possible use both configuration without closed NX and changing variable?
Best Regards
Marcin
