Impact Test of the furnance convection tube bundle A335 P22 3" x 7,62mm
I'd like to ask U is there another way to perform an impact test of the tube bundle material as I mentioned in the subject.
Charpy method is not fisible to be done because of the tube thickness.
During TA we had cut a part of the bundle to perform distructive tests and see what hapeness after 100.000 hours of work in 450 C deg.
One test that we are not able to do is impact test to see how brittle material is.
Thanks in advance.
Thanks in advance.
Never stop learning, because life never stops teaching.
RE: Impact Test of the furnance convection tube bundle A335 P22 3" x 7,62mm
As for the probe to the Charpy method 10x5mm is the smallest , I think that I will try to inform the supplier to try again and cut these probes.
Thanks for your answers.
