In-line Spray
In-line Spray
In-line Spray
Hi, every body.
In one export gas line, due to process requirements, butane and propane shall be injected to the line. Our process engineer said that there is no problem if you offset axis of spray from main line axis if there is no room (because of double spray in front of each other).
The question is:
Does this arrangement (non-concentric spray nozzle) make considerable noise with high velocity that exist in export gas line? (consider speed of gas in main line and spray are both within allowable)
