Removing scroll bars / adding buttons in UDF dialog box, UG NX
Hello All,
I have created a UDF in wizard with expressions by using expression rules (By Whole Number Range and By Number Range which is limited). The UDF contains values which needs to be entered while inserting UDF or scroll over to get desired value.
I would like to know the option of removing the scroll bars and add buttons in the dialog box so that the user has a flexibility of entering own values instead scroll from limited values.
What is "By options" in the expression rules of at UDF wizard box?
Vikram
