non uniform load over continuous spans
Just wanted to pick the brains of my fellow engineers out there. In your experience how have you gone about calculating shear/moment/deflection on a continuously supported member with a non-uniform (triangular) load. Obviously there is the easy answer of you can take the average and turn it into a uniform load and then use the moment and shear coefficeints from AISC. Or, there is the option of plugging and chugging in a computer (not a fan). Just curious of others' approach to this. Thanks to everyone who contributes on here.
RE: non uniform load over continuous spans
BA
I try to solve a couple of these by hand periodically. I aspire to be as good as the slide-rule era folks someday (to include the participant on this board that uses that moniker). And don't tell anyone but I still write with cursive.
But remember, the SR-71 was designed with a slide rule and the Osprey and F-35 debacles were designed with computers. Something to think about, to hopefully keep us humble...
for my money, BA's simple solution would mean using the peak as a UDL ... clearly conservative.
Quando Omni Flunkus Moritati
Mike McCann
MMC Engineering
VF22 shows that enough time and money can overcome all obstacles ...
Lots of triangles in that!!!
