60" HDPE storm to 60" RCP embedded in an existing headwall
I am replacing an existing ditch with two 60" HDPE Dual Wall pipes to match the (2) two 60" RCP culverts on each end of the ditch. Advance Drainage Systems (ADS) does not seem to have a typical connection detail for RCP to HDPE besides wrap couplers. This will not work due to the 60" RCP's are embedded/flush with a headwall. I have found some smooth wall inserts to use but it is not suggest to use downstream. I am connecting to the headwalls both upstream and downstream. I thought this would be a problem ADS ran into alot but they could not give me a solution last time we spoke. Let me know if anyone has done this before I am open to suggestions.
RE: 60" HDPE storm to 60" RCP embedded in an existing headwall
