Q about proportional control of home heater
Hi!
Hopefully this is not the wrong forum.Otherwise pls advice me.
I am considering to make a pc-controlled central heating system for at home.
Currently the house is heated by a Vaillant VCW255/3 heater. The heater can be contolled proportional by a thermostat in the living. I like to replace the thermostat with a pc. As far as I have understood the gas-valve is indirect controlled by a ventilator inside the heater. The more under=pressure the more the gas valve gets opened.
But..... How to control the fan external.
There are 3 wires from the heater to the currently used thermostat.
The two outer wires provide 24V AC towards the thermostat. The third wire controls (of course together with one of the others) the fan > valve.
Is there anybody who knows what kind of signal is generated by the thermostat to control the heater?
TIA
-Bart
TIA
-Bart
RE: Q about proportional control of home heater
Most home thermostats are not technically proportional, they are bang-bang, since none of the upstream equipment can be used in a proportional system.
TTFN
If this is a "just because you can" project move the question to forum1528: Engineers with Hobbies
If this is an actual work related project it's fine here.
>>>>>>>These fora should not be used to bypass your own in-depth research on the issues that affect you, nor is it intended to be a substitute for appropriate professional assistance within your field or geographical region.
Mint Julep, thanks for pointing me to a useable directon.
Without your help it should have been hard to figure out these matters.
IRstuff; bang-bang, such easy, should not require to ask for help from this helpfull forum.
Thread can be considered as closed.
KR
-Bart
