Electromagnetic Interference problem
I am performing vibration analysis on a motor that is around 50 feet away from the control panel.
The output of the data translation module I am using has a USB output, therefore I had to install A USB over CAT5 converter to run it out to the control panel (since the limitation on USB is 16.4 feet)
The only problem is that the contractor ran the cat 5 converter box right under a soft starter in the control room and now my program freezes every time I run the motor while connected inside the control room.
I need to leave a PC inside the control room for a few months and be able to remote into it for recording purposes.
I believe that the soft starter is causing Electromagnetic Interference with the USB to CAT5 converter and in turn causing my analysis software on my computer to freeze.
Would a Faraday cage solve this problem?
Are there any kind of EMI shielded USB cables out there? Or am I right about the USB to CAT5 Converter's circuitry receiving a massive spike from the soft starter?
RE: Electromagnetic Interference problem
First of all, I usually try to connect all power supplies to an outlet that has the same ground as the system I am recording signals from. That usually reduces common mode voltages so that the data transmission works.
Second, I use rather heavy HF ferrite toroids on the USB cable. Put as many turns as you can through the toroid.
If that doesn't help, get someone used to this kind of problems to help you. A Faraday - I do not think that will help. And it isn't practical to arrange in an effective way either. If it helps, it is usually because you will bond the different equipment together when you install it in a Faraday's cage.
Gunnar Englund
www.gke.org
This is a bit unclear. Is the box under the soft starter, or just the CAT5 cable?
In any event,
1. Is your USB to CAT5 converter in a metal box?
2. Shielded ethernet cable is available. Is yours shielded?
If you've got a plastic box and unshielded cable, the noise from the soft starter has two different paths into your system.
PS - please don't post the same question in more than one forum, unless you do so as described in the forum policies.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
I am measuring data from a motor 50 feet away.
I am using a USB of CAT5 ethernet converter to get around the USB length limitations (16.4 ft)
The data translation module is powered by the USB port on the PC (Which goes over the CAT5 until right inside the control room where it is converted back to USB, Coincidentally right under the soft starter)
The Converter box itself I think is getting Electromagnetic Interference from the soft starter right above it...
Any advice would be greatly appreciated.
The converter looks something like this Link
It is very seldom that such a converter is disturbed by emission "through the air". It is usually HF common-mode voltages/currents that cause the trouble.
You can illustrate that the "air" emission is miniscule by introducing a screen (copper plate or steel plate) between the two devices, ground the plate and see if anything changes. You do not need a complete "cage" to remove 20+ dB of interference, but you will probably still have the interference left in your system.
And, if that actually works - fine, there's your solution.
Did you try to increase the distance between culprit and victim?
Gunnar Englund
www.gke.org
It's only when the converter is inside of the control room that this problem occurs.
I have looked through the settings in the software and there is no type of filter option.
I am looking into something called Mu-Metal tape that might be the solution to my problem.
Gunnar Englund
www.gke.org
Would this be an option for wrapping around the USB over CAT5 Converter? Link
Thanks for all the help guys.
Dan - Owner
http://www.Hi-TecDesigns.com
Best to you,
Goober Dave
If I use the copper tape I linked in the post above, I assume I should ground it to something outside of the control panel where the soft starter is located.
I have attached a picture of what I have going on and the predicament I am in.
(Yes I know my artistic skills are pathetic at best)
Thanks for all the help guys!
Remember, shielding the thing is just an experiment as Gunnar mentioned above. It may or may not prove to be your solution.
Best to you,
Goober Dave
The program freezes when the soft starter kicks on but after I close out of the program and open it back up (with the motor still running) if functions as it should.
Any other ideas/opinions on this would be greatly appreciated.
Dan - Owner
Use a laptop (powered by battery alone, isolated on a wood table) instead of a desktop. If a ground loop is the issue, then the complete lack of grounding should break the loop.
PS: It's too bad that EMI isn't fuzzy red lines as shown in the sketch. It'd be so much easier if it were visible like that.
I thought it might be a ground loop issue so I installed a UPS powered HP PC out there a week ago and still the same problem exists...
Which leads me back to the USB over CAT5 Converter...
The CAT5 cable is UTP (Unshielded Twisted Pair) The USB is unshielded, and the Converter is a plastic box likely to have sensitive integrated circuity in it.
TTFN
Could anyone explain to me how a USB to Ethernet converter works? Could I use a USB to Ethernet converter on one end and just run the cat5 straight into my computer? Basically taking out the converter under the soft starter?
Are there any conflicting protocols I should be aware of?
Again, thanks for all the help guys.
TTFN
You have a vibration analyzer on the motor, and its output is USB. Your PC is in the control room. So out by the motor is a USB-to-ethernet converter and in the control room is an ethernet-to-USB converter for plugging into the pc?
Why not try a long USB extension and keep the active (repeater) portion outside of the room?
http://www.newegg.com/Product/Product.aspx?Item=N8...
Best to you,
Goober Dave
How about just getting some very large (2-inch wide) braid and shielding the entire cable including the dongle?
Beware one problem doesn't exclude the other. Be prepared to repeat the hand held laptop experiment in case it's both ground loop and EMI.
Keith Cress
Z
1."data translation" hardware is grounded or isolated from ground
2. how the cable is routed (tray, conduit), or it's degree of isolation from adacent power wiring.
sounds like a ground loop issue, there is test equipment for isolating gound loops, have youused such hardware?
When we move the computer (Laptop for this application) away from the motor and begin the vibration analysis everything works as it should.
The CAT5 cable that is run into the control room is, unfortunately, ran in the same conduit as the power wiring.
We have isolated the problem to the USB to Ethernet converter and it only seems to freeze the program when the USB/CAT5 converter is inside the control room.
Is a Faraday cage completely out of the question at this point? Wouldn't that shield the USB/CAT5 converter? Perhaps some copper tape wrapped around the device, then grounding the tape?
You've now lost whatever money _that_ saved, just in your time.
A separate conduit for the signal cable basically amounts to a Faraday cage, without the expense of trying to pull a foil-wrapped signal cable in with the unshielded one.
Mike Halloran
Pembroke Pines, FL, USA
I like ScottyUK's suggestion the best.
Best to you,
Goober Dave
Being as the (CAT5) data cable has already been run in the conduit with the power wires, I am thinking of simply replacing the UTP (Unshielded Twisted Pair) CAT5 cable with a shielded version of it and hopefully that will fix the problem. If not I don't see the harm in simply wrapping the USB/CAT5 Converter in something like aluminum foil essentially creating a Faraday cage for testing purposes.
Any other advice or suggestions would be greatly appreciated.
A simple steel box will be superior to any of them, every time.
Mike Halloran
Gunnar Englund
www.gke.org
move it
go spend $2.60 and buy shielded cat5 cable
www.KilroyWasHere.com
Mike Halloran
