Optimized Composite Box Beam Design
I'm trying to think of an optimized box beam design for a structure that is 30x7meters long and has a maximum height of 1.7m.
Does anyone know of feature that uses a optimized box beam design?
W.
RE: Optimized Composite Box Beam Design
I think you should post a bit more information, such as what you want use the 'design' for?
The number of obvious big box beams out there is pretty large. (Aircraft wings, bridges, truck trailers, buildings, pontoons.)
You've been fairly specific about the dimensions; can you tell us why?
