How should I change the diameter of all the pipes at once in EPANET
HI!!
I have laid out the piping network in EPANET for the golf irrigation system. After running the analysis, the pressure seems to be pretty high in all the pipes. So, I decided to increase all the pipe's diameter. I tried to change all the pipe's diameter by going in defaults but it seems that the new pipes will only get changed. How should I change the diameter of all the pipe all at once without changing each one of them individually because it will consume a lot of hours and I don't want to waste time. Please help me asap as I am trying to finish a project.
Thank You
ZorroEng
