wind turbine controlability
RE: wind turbine controlability
I have seen that before. It is old. That wouldn't have happened if the blades were feathered. This was mentioned in the first thread.
Peter Nachtwey
Delta Computer Systems
http://www.deltamotion.com
rb1957-
Most modern commercial wind turbines have mechanical and control systems designed such that this type of runaway condition should not occur. The blade pitch actuation systems are fail-safe designs, and there are rotor shaft brake systems that are also designed to be fail-safe.
I believe that was posted in the energy ( wind Solar.), conversion engineering forum some time back.
B.E.
You are judged not by what you know, but by what you can do.
