ASME B31.3 û Restrictive Temperature Limits of CS Materials Listed in Table A-1
Is there any way to de-rate the MDMT of A105 material used for flanges or valve bodies in B31.3 piping systems? B16.5 and B16.34 both restrict A105 to -29 deg C in their respective Pressure-Temperature charts and B31.3 Table A-1 also limits the min. temp. to -29C.
I am aware that for some materials (ex: A106 Gr. B), the MDMT without requiring impact testing is a floating value depending on the material thickness and stress ratio (see B31.3 Figures 323.2.2A/B); however, it has always been my understanding that for materials such as A105, the MDMT could not be adjusted below the values published in the specs/standards listed above.
Is this assumption correct or is there a way to de-rate the MDMT for A105 down to M45C?
Thanks in advance.
KDW
Thanks in advance.
KDW
RE: ASME B31.3 û Restrictive Temperature Limits of CS Materials Listed in Table A-1
Thanks again,
KDW
thread794-354475: Impact test temp for P-4 flange material
Still hoping to here back from anyone with an opinion on applying or restricting the same approach in a B31.3 piping system.
KDW
