Drying boiler tubes
Drying boiler tubes
Good day;
We are in the process of preparing for hydrotesting some OTSG units. The client will not be using them for quite some time after hydrotesting. The AI wants to see a procedure for drying the waterside of the tubes before we button everything up. Our intention is to use an oil free compressor and desiccant dryer to blow any moisture from the tubes. I'm wondering if anyone can give me a guideline as to what velocity of air we should target through the tubes? We intend to use a piece of cardboard to determine when the drying is complete. Any moisture on the cardboard means we have to keep drying. I'm wondering if anyone has any experience with drying boiler tubes? I'm looking for a rough idea how long the process will take. I'm guessing the drying time is a function of air flow and waterside volume, but would appreciate any insight you may have. I figured a couple of days for drying, but I'm just guessing.
Thanks in advance.
Brian
Thanks in advance.
Brian
RE: Drying boiler tubes
I have seen boilers dried with hot air from a trailer sized compressor which worked fairly well and took about a day. Can you use the gas turbine to dry it?
Is freezing a concern for you?
I will have to investigate the turbine option. I'm not sure if our client will allow it or not.
Yes, freezing is major concern. There are a lot of eyes on this project right now. I want to make sure we allow enough time in the schedule to properly dry the units.
I think that for storage, getting the unit down to -40C dewpoint is good enough, assuming it is an accurate reading. But I am always worried about tubes with water standing in low points and the air passing over the surface and leading you to believe it is dryer than you believe.
Yes it is initial hydro. I don't think the AI would have a problem with postponing. Our client is pushing to do it right away. The client is considering a nitrogen pad or just leaving dry air in it. Still waiting for a decision.
