Looking For Three Way SS V Port Ball Valves
I need to locate a manufacturer of 3 way V port 316 stainless steel ball valves with manual handles. In sizes 25 & 50mm rated to 1000 PSI either screwed BSP or flanged to ANSI600.
RE: Looking For Three Way SS V Port Ball Valves
I would start with either Dezurik and/or Fisher.
David Baird
mrbaird@hotmail.com
Sr Controls Engineer
EET degree.
Journeyman Electrician.
If it is going to be a small bore valve (under 4") and a characterized V Seat is acceptable then I would like to MCF Valve.  check out tycovalves.com for more information
