ASME code 2244
ASME code 2244
For cast body of a valve (material SA-995 grade 6A) say limitation on use as per code case 2244. What does it mean.
RE: ASME code 2244
RE: ASME code 2244
This code case is quite old,incorporated in ASME Sec-VIII, DIV-1 in Yr 2000.The material involved is the cast version of Zeron-100(see the attachment).It's not clear from your enquiry what's the real design and selection issue with this casting, except that this material,like all other Duplex and Super Duplex stainless steels has limitstions with respect to high temperature applications.
Appreciate if you could post more details.
Pradip Goswami,P.Eng.IWE
Welding & Metallurgical Specialist
Ontario, Canada.
ca.linkedin.com/pub/pradip-goswami/5/985/299
