Selecting objects
Selecting objects
Selecting objects
When I use Draftsight I can pick as many objects as I want before doing something like the MOVE command. However, I have a co-worker who can only pick one object at a time. If he picks a line it will highlight but if he picks a second line the first one un-highlights. As far as I know, he has not done any customization but perhaps he inadvertently changed something.
Anybody know how to fix his system so he can select multiple objects at the same time?
RE: Selecting objects
I don't remember exactly. There is a previous thread in here about that. Try searching for it.
Turns out I had the same problem myself & when I search for the solution I found my old post. Doh! Problem solved.
