[NX 8.5] Advanced Simulation Results
I'm got my mesh defined, material assigned and constraints proper. I solve the model and it converges with no errors. When I think attempt to display the results I get an error that "No results are found".\
WHAT DOES THIS MEAN?!
Please any help will be great.
Thank you in advance
- Justin Heckman
RE: [NX 8.5] Advanced Simulation Results
This means that the solution gave error. Open the *.F06 (this is the nx nastran output file in ASCII format) located in the same directory as the *.SIM file and look for the word FATAL, there you will have the description of the error.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
What if I'm working with Teamcenter. Will these files output to another folder locally?
- Justin Heckman
The *.F06 nastran output file is located in the same directory of the NX *.prt part, in the same place as the *.FEM file or *.SIM files, make a search.
Best regards,
Blas.
Blas Molero Hidalgo
Director
IBERISA
