GA. NO. and GA. notes in dimensions on drawings for mfg.
I have a drawing with some dimensions that includes the note GA. NO. or sonly GA.
what is the meaning of that notes?
thanks.
thanks.
RE: GA. NO. and GA. notes in dimensions on drawings for mfg.
John-Paul Belanger
Geometric Learning Systems
Gauge is used a lot in the metal industry as a thickness measurement.
Ben Loosli
Gage
Gas Amplification
Glide Angle
Graphic Ammeter
Ground-to-Air
NO can mean Normally Open or number.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
the drawing that I am talking about is for machining a body of butterfly valve, where diameter dimensions are following by the note GA. NO.
example (dia. 4.879 / 4.876 GA. NO.)
thanks again.
Usually used on a tapered surface, you would have a gage diameter and a gage height.
Measure the diameter at that height and it needs to meet the gage diameter values.
Ben Loosli
