H2S Removal Via MDEA Spray Nozzle
Looking for a very economical way to sweeten up a gas/vapor stream that is really low pressure. My thoughts were to use MDEA with a few fogging nozzles and then knock out the liquid downstream. Any comments or personal experience with this? I guess what I am really wondering is if you could get adequate contact to remove the H2S or if the contact efficiency would be so terrible that you'd have to use enormous amounts of MDEA?
Thanks.
Thanks.
RE: H2S Removal Via MDEA Spray Nozzle
