Undo define title block.
NX 9 I created some tables and oriented them into a title block and imported an image into one of the cells and so forth until I was happy.
Then I define the title block and later populate it no problem but can I undo the define title block so that it goes back to the original tables.
also is there some good reason why I can not copy and paste a title block say on another sheet or even a different part, I can copy and paste tables no problem.
Thanks B.
RE: Undo define title block.
I don't know why you can't re-edit a defined titleblock, I saved a "editable" template backup file before I defined it so if I need to make changes I can go back to the pre-defined template. Good luck...
