Red Lining & Markup of PID / ISO's
I would be curious to know what type of Software is used out in Industry for this application. Our company uses Adobe XI...and to be frank about it, I do not find it very user friendly...althoughj I readily ademit to not being an expert Adobe.
Is anyone using a dedicated markup type of Software.??
Thanx - and I look forward to your replies.
Cheers and have a good weekend..!
RE: Red Lining & Markup of PID / ISO's
Red Lining & Mark-up of P&ID & Isometrics
Some people still use the "Col-Erase" (Carmine Red) wood pencil Model #1277" it works great.
- It is light weight and portable
- It is intrinsically safe to use in areas with high concentration of flammable vapors
- It is erasable ( The Undo command is easy to learn)
Question:
Why was this posted on a "AWS Welding & Code Forum"?
A forum about Process Engineering and/or Piping might have been better.
prognosis: Lead or Lag
The world is awash with those that simply can't handle change... Well, you stick with your pencil sonny.!
My question stands and is applicable to any of the mechanical forums.
Im looking at BlueBeam Revu...anyone do a comparison with Adobe XI..?
