large deflection analysis for a shell structure does not converge
I cann't get any results from this kind of analysis, does any one has solution?
thanks
RE: large deflection analysis for a shell structure does not converge
Recheck which DOF is used for convergence criteria.
how to do this? for example if I have large deflection along U1 direction, should I set "monitired displacement" DOF to U1 right? how about "load applicationcontrol", should I choose "displacement control"
thanks
Displacement control is more stable in most cases, so you can try that.
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
attached a simple model, but not sure the large deflection analysis results are correct or not, anyone has idea?
thanks
