HSS - End / Cap Plate Weld
Is there a 'best' or most economical weld for a cap or end plate connection to an HSS member?
Assuming the cap plate will take load similar to this lifting lug problem:
http://www.eng-tips.com/viewthread.cfm?qid=256993
You could weld around the inside or outside using a groove weld or you could oversize the plate and provide a fillet weld. Is there one in particular that is better or ones that should be avoided?
I would preferably use the outside complete-joint penetration square (or V) groove weld with backing. Any issues with that?
RE: HSS - End / Cap Plate Weld
The cjp welds will, if im not mistaken, require a backer bar (not easily accomplished) or backgouging, which is not possible with a closed hss.
So with that, a pjp weld is probably a better way to go.
BUT, for 1/4" hss member thicknesses, it usually leaves you with an 1/8" maximum effective throat. see pg 8-55 for geometric limitations of the PJP BTC-P4.
If you can get away with it, a fillet weld will require no preparation that is usually required for CJP and PJP welds and will be the easiest solution.
www.FerrellEngineering.com
Providing fabrication and erection efficient structural design of connections. Consulting services for structural welding and bolting.
