circularity tolerance greater than the size tolerance without using "AVG"
thread286-298925: CIRCULARITY/ROUNDNESS TOLERANCE APPLIED
I had look thru most of the thread but can't find the answer.
If I have a part diameter of 14.000" +/-.005", and the call out for circularity is .100 (F). I know this is a free state part, but there is no "AVG" called out for this feature.
So, for this case, what would be the max or min of the diameter? Or there is a typo in the print?
Thanks for the help!
RE: circularity tolerance greater than the size tolerance without using "AVG"
As I notice from the ASME Y14, "AVG" comes with the size tolerance and the feature (circularity) tolerance is greater than size tolerance, it is "valid"; and we can have minimum 4 measurement and get the average. That I have no question about it.
Now, if the drawing is missing "AVG", and the feature tolerance is greater than size tolerance, what should be the acceptable diameter? Or this is a typo?
John Acosta, GDTP S-0731
Engineering Technician
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
Nothing showing "PERFECT FORM AT MMC NOT REQUIRED".
-By the way, if it indicate "PERFECT FORM AT MMC NOT REQUIRED", what should be the spec of measurement?
-Regardless of the feature tolerance, if I make a "gage" to check the maximum diameter, and if the part does not fit in, can I say it is out-of-round? The gage is as simple as a block having a 14.006" diameter cutout.
The circularity tolerance of .100 is to be checked in the free state, so it's a different situation. In the Y14.5 standard (2009 edition, end of paragraph 5.5.1) it says that the F symbol "separates the free-state requirement from associated features having restrained requirements." Because of this separation, I see it as being a different requirement than Rule #1 and thus legal.
John-Paul Belanger
Geometric Learning Systems
2. If for the second condition (circularity tolerance of .100", at free state), but it is without the "AVG" (as per drawing), what would be the max/min diameter? Is it still valid to use this AVG (average) method:
==taking at least four measurements and average it up and average value should be within the size tolerance; the data of measurement should fall in one of the condition:
Condition 1: 14.005+.100=14.105 (high) and 14.005-.100 = 13.905 (low)
OR
Condition 2: 13.995-.100 = 13.895 (low) and 13.995+.100 = 14.095 (high)
OR
John-Paul Belanger
But why there is no spec for the diameter in the Free state? Is it because of the "NOTE"?
I think the purpose of the circularity in the free state here is just to make sure that the shape is somewhere in the ballpark of the correct shape, so that the part isn't overly stressed when restrained to its real, functional condition.
John-Paul Belanger
