Bearing reistance of joints
Hi guys,
Regarding the design of connections I have a couple of questions on the bearing resistance of a joint subjected to tension.
1) bearing resistance is a the crushing failure of bolt or plate?
2) Please see attached picture/image. If you cannot see image I will describe. You have a joint subjected to double shear. Plate thicknesses are a and b. Plates a are on outside and plate b sits inbetween. If thickness b > a then is b the thickness to use in bearing resistance calculation? If so why is this?? I am designing to Eurocodes 9 - joints.
Thanks so much
Darragh
Thanks so much
Darragh
RE: Bearing reistance of joints
