Depth of acquifer
Depth of acquifer
Depth of acquifer
How is depth of acquifer known or measured. Is it provided by local agencies. It is of course important to know the depth of acquifer to dewater soil. How do you get it?
RE: Depth of acquifer
The term aquifer is intangible. If you are installing a well for domestic use, the aquifer may be completly different than if you are installing a well for industrial use. An aquifer is any layer of soil that is being expolited for a specific use.
If you are working on a project that's realted to construction dewatering, you are dealing with different issues. Who cares whether you get a certain quanity of water, you are more concerned about reducing hydrostatic pressure at the base of the excavfation and providing stability to the excavation sidewalls. So, you need to concern yourself with the water pressures (well readings) and permeability of all the layers.
Now, what to do below the bottom of the excavation? Well, you need to know the same things to some depth where there is a significant contrast in permeability to allow the assumption of "impervious." If your cut is 20 ft, you'd likely need data 10 ft below the bottom of the excavation unless you're still in some pervious layer.
This is a case where experience and good judgement goes a long way. Not that it's complicated, it's just hard to say in such a general discussion.
f-d
¡papá gordo ain’t no madre flaca!
generally well drilling logs are used to infer the depths and elevations of groundwater aquifers. you may be able to get this data from the water resource agency. however, for a dewatering project, you really need to do your own investigation at the point of interest to determine the approximate depth to the water table and the other soil properties that might affect the yield of a dewatering well. suggest that you need to hire a hydrogeologist that can assist with your project
For these posts, if you explain better what your project is, it is very likely you will get the help you need. As it is, we can only guess what your situation is. Post a picture if you can.
