Member Login
HANDLE
PASSWORD
Remember Me
Forgot Password?
  • Turn Off Ad Banners
E-mail*
Handle
Password
Verify P'word
Partner With Us!
Partner Button
(Download This Button Today!)
Member Feedback
"...I frequent other newsgroups, too, and am MOST IMPRESSED with the lack of smart a-- and presence of genuine desire to help anyone of any skill level..."
Geography
mmaurigi (Mechanical)
31 Oct 02 21:45
I need to design a float that is attached to an arm that will open or close a butterfly valve that controls the level in a retention tank. It is identical the way the float works in a typical toilet. As the level decreases, the float moves down and opens the valve allowing more water in. As the water level rises, so does the float and that closes the valve. I've contacted the valve manufacturer and he said the shut-off torque for the valve is 850 in-lbs. I was figuring that the lever arm from the centerline of the valve shaft to the float would be about 36in. How do I calculate the size of the float so that will in fact float yet be able to provide the required torque to shut off the valve. If you can give me a hand with this I'd really appreciate it.
abeltio (Mechanical)
1 Nov 02 22:40
This is a rough approach...
850in-lbs/36in = 23.6lbs
The volume of water that will give an upward force of 24lbs is 24lbs/[62.43 lb/cuft]= 0.384cuft
Design a sphere that will have a volume of 0.384cuft when submerged 1/6 of the diameter.
HTH
Saludos.
a.
Start A New Thread
Promoting, selling, recruiting and student posting
are not allowed in the forums.
Posting Policies
LINK TO THIS FORUM!
(Add Stickiness To Your Site By Linking To This Professionally Managed Technical Forum)
TITLE: Valve engineering Forum at Eng-Tips
URL: http://www.eng-tips.com/threadminder.cfm?pid=408
DESCRIPTION: Valve engineering technical support forum and mutual help system for engineering professionals. Selling and recruiting forbidden.
