Looking for tubing or bar stock in 5.5"
Anyone have a line on who make 5.5" bar stock or tube with no more than a 3.5" bore?
Rich
Rich
RE: Looking for tubing or bar stock in 5.5"
Search on 'hollow bar'.
Mike Halloran
Pembroke Pines, FL, USA
arcillor mittal may have the material. I will have a quote tomorrow. I was hoping to find more than 1 vendor in the states.
Rich
The tubing will save considerably on machining costs if the dimensions are close enough.
who has the capability to perform this toll work? We are looking for MIll quantities 10-20K# I have also considered having heavy wall 5.5" tube rolled to the hex shape as long as reasonable tolerances can be held.
Mike Halloran
If you require short length rings of 5.5" OD x 3.5" ID, then purchasing roll forged rings might be a good option. The material can be roll forged into a thick walled tube to a length of around 6-8 times the OD, and then it can be parted off into the short length blanks you require. The nice thing about roll forged rings is that there is very little material scrap.
