API 650 Wind Moment
API 650 Wind Moment
I am trying to calculate the wind moment applied on vertical tanks based on API 650.
Per API 650 sec 5.2.1.k ([18 lbf/ft2][V/120]2) on vertical projected areas of cylindrical surfaces and ([30 lbf/ft2][V/120]2) uplift on horizontal projected areas of conical or doubly curved surfaces.
Any suggestions on how to calculate the Moment once the wind pressure is determined?
Thanks in advance!
Thanks in advance!
RE: API 650 Wind Moment
The wind pressures calculated are used on the projected areas of the tank to calculate the moments.
2)Vertical Wind force on the conical surface = Fr =Pi()/4* D^2 X PWR.
3)Overturning moment about the shell-to-bottom joint from horizontal + vertical wind pressure Mw= Fs*H/2+Fr*D/2
Thanks!
PWR = Pressure of Wind on the Roof
