MidCon Channel Slab - Bracing
I am working on a job where the client is using precast channel slabs to install a new roof system. The channels slabs are manufactured by a company called MidCon. I would like to know if these channels slabs can be used to brace the compression flange of the beams below. I called the manufacturer and they had no data regarding this issue. Does anyone have any experience using this product? If so, could you provided information on the channel slab's ability to brace the compression flange of the beam below.
