Line size & flow
Line size & flow
Line size & flow
I have a Zone 1 triplex pump and the inlet is 4" 206 and the discharge is 2" FIG 1502
I want to measure the flow and i had only 4" turbine meter, when i rig-up with the line and the flow is not as per the data-book.
How can i get the required flow.
I don't have 2 " turbine meter.
Rgs
symon
RE: Line size & flow
Got a barrel and a stopwatch?
Mike Halloran
Pembroke Pines, FL, USA
Rent a magnetic flow meter or ultrasonic?
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
if you have a positive displacement pump a turbine meter will not work as you've discovered,
you'd be better of with pump rpm's
not an easy measurment unless you have flow pulsation dampeners and suitable piping layout
