Journal to delete all file attribute properties
someone has a journal to delete all attribute properties in the file ?
Thank you...
Using NX 8 and TC9.1
RE: Journal to delete all file attribute properties
This deletes all of the unlocked part attributes from the workpart.
HTH,
Joe
CODE --> .Net
' Delete all unlocked part attributes from the workpart. Option Strict On Imports System Imports NXOpen Module NXJournal Dim theSession As Session = Session.GetSession() Dim theUI As UI = UI.GetUI() Sub Main (ByVal args() As String) Dim workPart As Part = theSession.Parts.Work Dim atts() As NXObject.AttributeInformation = workPart.GetAttributeTitlesByType(NXObject.AttributeType.Any) Dim titles(atts.Length - 1) As String For ii As Integer = 0 To atts.Length - 1 titles(ii) = atts(ii).Title Next Dim locked As Boolean = Nothing For ii As Integer = 0 To titles.Length - 1 Try locked = workPart.GetUserAttributeLock( titles(ii), NXObject.AttributeType.Any) Echo("") Echo(titles(ii) & " locked = " & locked.ToString) If locked = False workPart.DeleteUserAttribute(NXObject.AttributeType.Any, titles(ii), True, Update.Option.Now) End If Catch e As Exception theSession.ListingWindow.WriteLine("Error: " & e.Message) End Try Next End Sub Sub Echo(ByVal output As String) theSession.ListingWindow.Open() theSession.ListingWindow.WriteLine(output) theSession.LogFile.WriteLine(output) End Sub End ModuleRE: Journal to delete all file attribute properties
the journal works perfectly.
Thank you.
Thank you...
